How to keep the temporary solver memory from being freed in ANSYS Fluent 18.2 for multiphase models?
Tagged: 18.2, fluent, fluid-dynamics, General, MP - Eulerian MP Flow, Other
June 5, 2023 at 7:06 am
FAQParticipantStarting with Fluent 18.2, it is no longer possible to use the TUI command /solve/set/expert to keep the temporary solver memory for multiphase simulations. If you want to access intermediate results like gradients you must use a UDF to recalculate the required values. See also Fluent 18.2 Migration Manual, New Limitations in ANSYS Fluent 18.2
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
