In solving a VOF problem with Coupled Level Set, I click the Surface Tension tab of the Phase Interactions, and find I cannot set the Continuum Surface Force and Continuum Surface Stress surface tension models. Instead, the only options are Wall Adhesion and the value of the surface tension coefficient. How can I restore the surface tension model option?
June 5, 2023 at 7:06 am
FAQParticipantWhen the coupled Level Set option is selected for VOF, a revised surface tension formulation is used internally. CSS/CSF are therefore disabled in the Phase Interactions. The Level Set option is helpful in cases where surface tension effects are strong enough to destabilise the numerics, but offers less customization.
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
