Spaceclaim direct modeler (SCDM) doesn’t start when launching either from workbench or from the start menu.
June 5, 2023 at 7:06 am
FAQParticipantLook for a recent file in C:ProgramDataMicrosoftWindowsWERReportArchiveAppCrash_SpaceClaim.exe_
Report.wer The file will report the module the crash happened in, eg Sig[3].Name=Fault Module Name Sig[3].Value=ntdll.dll Then it is a case of searching on line for possible reasons why the reported dll could fail to see if any correspond to the current system. In the case of ntdll.dll reported above, some webcam software/drivers can conflict with some applications and a webcam had recently been installed. Uninstalling the webcam allowed spaceclaim to run.
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
