June 5, 2023 at 7:05 am
FAQParticipantIn SCDM, Groups tab, see if the Named Selections all show up with using “View groups in” is set to “Root Part”. If groups are created for active parts, then these component groups should be imported to the root part. To do this, right click on the component and select “Import Component Groups”. Then update the geometry in the Mechanical / Meshing application
