June 5, 2023 at 7:05 amFAQParticipant
Yes, the ASCII data was taken out of the WB LS-DYNA GUI at V18.1. The access to the data moved to either in the Energy Summary under Solution Information; or a Result Tracker that can be inserted under the Solution Information object.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
