Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantfile.cnd has the contact force component data for each contact pair:
Contacting Area Total contact force due to pressure -x component Total contact force due to pressure -y component Total contact force due to pressure -z component Total contact force due to tangential stress -x component Total contact force due to tangential stress -y component Total contact force due to tangential stress -z component One can use trackers to extract data.
