General
General
How to implement tension only cable in ANSYS Mechanical?
    • FAQFAQ
      Participant
      Use Line Body to model cable. Insert a Command Snippet under Line Body to define tension only element. Example of Command Snippet: ET,matid,LINK180 ! material number for this body is “matid” SECTYPE,matid,LINK SECDATA,0.01 ! set section area SECCONTROL,0,1 ! set section to be tension only
