Tagged: 17.2, Ansys nCode DesignLife, DesignLife, fatigue, General, nCode, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantYes, but some of DesignLife’s advanced features are not valid. Those features must be deactivated. In Advanced Edit > Analysis Group > Select Groups > Entity options, you must set to “False” the following options. 1.SurfaceNodesOnly 2.ResolveToLocal 3.StressGradients In Advanced Edit > SNEngine >, you must set MultiAxialAssessment to “None” and StressGradients to “Off”. In the Material Mapper, you must uncheck the “Validate Before Run” option.
