Tagged: 19.2, Designer, Differential lines., Electromagnetics & Electronics, Group Delay, hfss, linear, nexxim, workflow
May 25, 2023 at 7:29 am
FAQParticipantGroup Delay for differential lines has not been implemented as a defined quantity to plot but it can be derived by the S-parameters calculation of the differential mode by manually write the output variable: deriv(ang_deg(S(Diff1,Diff2)))/2/pi*1e12
November 19, 2024 at 6:58 am
zhengdongliu@o-netcom.com
ParticipantIs it possible to plot differential group delay with HFSS?
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- How to Create Bondwires in 3D Layout ?
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
