Tagged: 18.2, cfx, fluid-dynamics, MP - Particle Tracking, multiphase, particle, post-processing
May 15, 2023 at 8:32 am
SolutionParticipantA new expert parameter was introduced in CFX-Pre 18.2 to write the particle mass flow variable to the res file so that it is available in CFD-Post. The parameter is: pt force export massflow = t Instructions for setting this parameter are attached.
1. 2052304.pdf
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
