Do you have an example for bolt modeling using BodyToBody Beam connections in the Workbench LS-DYNA extension
April 13, 2023 at 7:32 am
SolutionParticipantThe attached example project file (archive) demonstrates how to model BodyToBody Beam connections in Workbench LS-DYNA.
1. 2053649.zip
