Tagged: 2019 R2, cfx, fluid-dynamics, MP - Particle Tracking, multiphase, post-processing
April 13, 2023 at 7:32 am
SolutionParticipantPlotting particle slip velocities may be desirable to view separation regions due to particle inertia effects, particle slip near moving walls etc. Although particle slip is not directly available as an export variable from CFX, it can be defined as a new variable in CFD-post. Please refer to the attached document to access the solution.
1. 2060308.pdf
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
