Why do DesignModeler versions 2021R2 and 2022R, sometimes stop working, when running on a Windows operating system. Producing the message, Warning: DesignModeler license has expired. All modelling operations will be disabled. You will be able to save your work.
April 13, 2023 at 7:32 amSolutionParticipant
Please see attached .pdf document for the resolution.
1. 2068136.zip
- Q: How do I set the license server from my client machine?
- Failover feature ‘Discovery – Level 1’ is not available
- How do I configure RSM to send a solve to a remote machine (no scheduler)?
