Tagged: 19.2, acoustics, damping, mechanical, structural-mechanics
April 5, 2023 at 2:32 pmFAQParticipant
In acoustics, we don’t really have damping except viscosity (some energy loss within the fluid), which is input as a material property, although this is usually a small amount of energy loss. The structural damping is the main source of energy loss and should be specified the same in both analyses (in harmonic, “Analysis Settings” allows specification of damping).
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
