Tagged: 18.2, General, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThis JOINT tolerance is used to check on satisfaction level of Joint constraint. For example, if it is a universal joint: some of the constraints for node I, J are: UxI = UxJ, UyI = UyJ, UzI = UzJ, During the Newton-Raphson computation, these constraints are ‘exactly” satisfied if || Ui — Uj || < || JOINT tolerance ||, code interprets this as converged.
