General
General
How can I open a project page wizard ?
    • FAQFAQ
      Participant
      – First, you need to install the extension : open a Workbench Project Page, go to the ACT start page, select “Manage Extension” and install the extension. – Then, load this extension. – After the extension is loaded, return one step backwards, and from the ACT start page, select “Launch Wizard”. You will then be able to click on the Wizard you wish and use it.
