EM_FAQ: How is possible to export TXT file of results that contain coordinates and values of variable, for example loss?
March 17, 2023 at 1:12 pm
SolutionParticipantTo Export a quantity (B field, Loss, etc) you need to: 1/ Open the Fields Calculator 2/ Introduce the Quantity you want to export for example Quantity -> Ohmic Loss 3/ Go to Output -> Export (introduce the file name and the values of the grid). A file will be generated with the Ohmic Losses in all the points of the specified grid. In the attached image you can see the steps mentioned above.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
