March 17, 2023 at 1:12 pmSolutionParticipant
Foam material is a porous material and should be better handled by the material models that account for porosity. In ANSYS Explicit Explicit Dynamics, the material models that can take porosity into account are * crushable foam * compaction EOS linear * compaction EOS nonlinear * P-alpha EOS. For the foam material if going to be used in drop test, impact or crush simulations, one may consider to use crushable foam material model. Please keep it into mind that the stress/strain relation used in this model is the relation between principal stress and volumetric strain. Please see the attached online help (.pdf file) on crushable foam model for more information. Also find attached a workbench sample file for reference using a rigid ball to impact a foam block.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
