March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2044754.pdf
2. 2044754.zip
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
