Tagged: 17.2, fluent, fluid-dynamics, MP - Particle Tracking, post-processing
March 17, 2023 at 1:11 pm
SolutionParticipantDPM and MRF can be combined to quickly estimate the behavior of particles in moving domains. However, one must be careful when using such models as strong errors can occur when considering relative velocity for particle tracking. These errors can hinder the prediction of erosion/accretion rates of particles on walls, especially for heavier particles as shown on the test case. See attached pdf document for further details.
1. 2046291.pdf
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
