How to print Additional Data (eg. Heat Transfer Coefficient) along the Fiber Length in the FLUENT Fiber Module
Tagged: 17.2, fluent, fluid-dynamics, MP - Particle Tracking, post-processing
March 17, 2023 at 1:11 pm
SolutionParticipantBy default, printing the fiber data writes out a *.his file containing basic information along the fiber length such as length, velocity etc. If you need additional data to be printed, such as heat transfer and mass transfer coefficients, it can be done by changing the following rpvar: (rpsetvar ‘udf/fm/extended-output? #t) Please refer to the attached document for further information and examples.
1. 2046963.pdf
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
