How can the number of injected parcels at a surface could be reduced in a simple way when using the standard release method?
March 17, 2023 at 1:11 pm
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
