Tagged: 18, fluent, fluid-dynamics, General, General - FLUENT, parallel
March 17, 2023 at 1:10 pmSolutionParticipant
For a parallel case file, one needs to read/write the case file first and then issue a command: (print-case-timer) For a parallel data file: (print-data-timer) The timer can be reset to zero via TUI: /parallel/time/reset For measuring the performance of the serial solver, the following commands in the console window can be used: (benchmark ‘(read-case “filename”)): read time of the case file (benchmark’ (read-data “filename”)): read time of the data file (benchmark ‘(write-case “filename”) ): write time of the case file (benchmark ‘(write-data “filename”)): write time of the data file.
1. 2043251.pdf
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
