It is possible to change the normal stiffness factor of a contact pair between the load steps using the Contact step control object.
Tagged: 19, contact, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantYes, the Contact step control can be found by picking on the environment branch in the Mechanical tree (such as Static Structural) and then picking Conditions in the toolbar. There you will find the Contact step control object.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
