In ANSYS Release 11.0, can querying the subgrid identify multiple items at the same location for SHELL181 elements?
March 17, 2023 at 9:00 am
FAQParticipantYes, the subgrid query does not operate on the actual model; it operates on the “graphics object.” PowerGraphics (/GRAPHICS,POWER) takes the displaced coordinates of the SHELL181 elements and expands them into 3D faceted “graphics blocks” to create this graphics object. The contour colors are assigned at each block corner (top and bottom surface), and the contour values from adjacent blocks are not averaged. The picker uses a view vector from the centroid of the model to the user’s eye to traverse the model. Depending on the orientation and displaced shape, multiple grid points can lay along any given view vector. Thus, the subgrid picker will find multiple items at one location any of the three following reasons: (1) values exist for the top and bottom shell surface (2) multiple values exist at the same location from the faceted adjacent elements, and (3) multiple locations exist along the view vector.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- ANSYS Mechanical: Node Move
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
