General
General
Why CAD associativity between ANSYS & SolidEdge is lost even when nothing has been changed in CAD?
    • FAQFAQ
      Participant
      Problem: Possible defect where CAD associativity between ANSYS & SolidEdge is lost. Simply clicking on “Update Geometry from CAD” causes contacts to loose scopings. Answer: This is most likely due to instances. If you import with that option turned off it would likely work better, or import and immediately update before setting the boundary conditions. This is a limitation as of current release (2019R2)
