General
General
How to remove a material from the favorites list in engineering data library?
    • FAQFAQ
      Participant
      To remove a material from the favorites: 1) Import the material into the engineering data project. It will then appear under the Materials folder. 2) Right click on the material name under the Materials folder and uncheck the Favorite Source item.
