Why does a thermal analysis sometime write the results to a file with a .RST extension (e.g., in the thermal pass of a thermal stress analysis)?
March 17, 2023 at 8:59 am
FAQParticipantIf the model contains more than one DOF type, the results are written to a .RST file, regardless of the solution type. So, for example, if a thermal model also contains structural DOFs, the results are written to a .RST file rather than a .RTH file.
