How do I change the diameter of a circular beam profile created in SC? Only the section properties (Area, Ixx, Iyy,Ixy) appear to be exposed for editing in the Details window of the Beam Section Folder.
March 17, 2023 at 8:59 am
FAQ
ParticipantThe beam profile is locked by default. Highlight the “Circle” item under Beam Profiles Branch and RMB to uncheck the “lock” feature. Then RMB “Circle” =>Edit Beam Profile… A new Geometry tab will open with the beam profile in sketch mode. The radius of the circular section will appear in the Driving Dimensions Folder for editing. After modifying the radius, close beam profile geometry tab. Re-lock the beam profile in project tree and save the geometry.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
