March 17, 2023 at 8:59 am
FAQParticipantThe following suggestions should help fix this problem and the layered tet method control should become valid: 1. Deleting the body size control on the build part. 2. Deleting the Cartesian method control. 3. Turning off adaptive size function and turn on curvature size. 4. Automatic support body generation is not supported. Any required support needs to be manually generated prior to meshing and merged with the original build body.
