Tagged: ls-dyna, LS-DYNA Suite, lsdyna, structural-mechanics
March 17, 2023 at 8:59 amFAQParticipant
In this scenario, a straightforward way to obtain the relative rotation is to define a *CONSTRAINED_JOINT_STIFFNESS_GENERALIZED in conjunction with the *CONSTRAINED_JOINT_REVOLUTE. This will trigger the output of the relative joint rotations in the output file JNTFORC, which can be accessed through LS-PrePost. To this end, the *CONSTRAINED_JOINT_STIFFNESS_GENERALIZED keyword will only require the definition of the fields in Card 1. The remaining cards can be left blank if no joint stiffness, stop angles, etc. are required.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
