March 17, 2023 at 8:59 amFAQParticipant
To improve speed please try following settings -Turn off element self interaction -Turn off Part self interaction (if possible) -Turn on 1 point Gauss Hex -Use mass scaling (for overly small elements) -Use the SCP Tet (much faster, but less accurate)
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
