General
General
How to get input file for AUTODYN from WB Mechanical?
    • FAQFAQ
      Participant
      For getting the input file, you need to run the solution for at least one cycle and then the cycle zero file would be admodel_0.ad in solver file directory. Please note that it can only be opened in Autodyn GUI, it is not the same as APDL commands file that can be edited in text editor.
