- All Categories
- Fluids - Postprocessing
- Adding axis to a contour plot in EnSight
Tagged: 2019 R1, ensight, fluid-dynamics, General, Visualize Data
March 17, 2023 at 8:59 am
FAQParticipantAxes plot can be added to a contour plot by turning on visibility of the 2D bounds. To do this: 1. In the view menu, turn of the bounds visibility. 2. In the Viewport settings, set the viewport to be 2D. Right-click on the viewport -> Edit to open the ‘create/edit viewports ‘ dialog box. Change ‘View Dimension’ from 3D to 2D. The axes, thus created, will use the dimensions of the model. If you wish to normalize them, you’ll need to normalize the model part itself (by double-clicking on the part in the part-list, and set a scaling / offset factor). You should be able to label the axes using text-annotations. Keywords: display axes, contour plot, EnSight, bounds visibility
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
