March 17, 2023 at 8:59 am
FAQParticipantThe particle source term linearization option in the Fluent particle tracker activates or deactivates the linearization of the particle sources into the coupled gas phase. It does not alter the tracking sequence or tracking frequency. To update the particle sources with the updated fluid data you have to call the particle tracker again.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
