Tagged: 19, cfx, fluid-dynamics, MP - Particle Tracking, multiphase, transient
March 17, 2023 at 8:59 am
FAQParticipantThe particle source term data and current particle positions from the initial values file are used, if you follow the instructions below: GUI: ANSYS CFX Solver Manager ->Define Run>Initial Values Tab: Activate: Continue History from Continue History from: Initial Values File Use Mesh from: Solver Input File Command Line: Use one of the following options on the command line: -continue-from-file
-cont-from-file Use initial values and continue the run history from the specified ANSYS CFX Results File. The mesh from the Solver Input File is used unless the -use-mesh-from-iv option is also specified. Key Words: Lagrangian Particle Tracking, Lagrange Particle Tracking, transient, restart, modified mesh, changed mesh
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
