When I export an EnLiten file I get the following error: “This model doesn’t have a supported animation type in use for EnLiten output”
March 17, 2023 at 8:58 amFAQParticipant
EnLiten scenarios can save animations only from flipbooks and keyframes, they won’t make an animation from the Solution Time.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
