March 17, 2023 at 8:58 am
FAQ
ParticipantThe calculation terminates with the error message “zero pivot for the pressure”. It usually happens on a mesh involving triangles and tetrahedra along boundaries. When using a mesh which contains triangles (in a 2D geometry) or tetrahedra (in a 3D geometry), one must take care that all elements have at least one node in the interior of the domain. This is especially true when boundary conditions are imposed in terms of velocities, where most equations for the pressure reduce to 0=0 and a zero pivot is generated for the pressure unknown.
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/06/Ansys-Cloud.jpeg)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/03/Optical-1-1.png)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/03/Geko_Video-1-1.png)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/06/EnSight_PP.webp)
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
