In the ACT Machine Toolkit: where are the files that contain the initial setup information as well as the output data?
February 6, 2023 at 2:42 pm
FAQ
ParticipantThe input file data can be generated saving the toolkit settings. To do this, select the option: “Save toolkit settings to file”, under “Toolkit Analysis Options”. This file can then be uploaded in the toolkit and re-used or modified. To do this, select the option “Prefill Settings using…” under “Project/Design Selection”. The output data file (for the efficiency map data) is located the *.aedtresults folder. See file “..EffMap.asol”. You can also export the efficiency map points using RMB on top of the Efficiency Map and selecting Export.
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to fix messed up Windows layout?
- Cloud Computing from Electronics Desktop
- What are the available boundary conditions in Maxwell?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to create and manage a queue of simulations?
- Are solid losses and eddy losses the same in Maxwell?
- How to calculate capacitance and inductance in Maxwell Transient solver?
