January 25, 2023 at 7:34 am
FAQ
ParticipantAppendix A of the ANSYS Parametric Design Language Guide has info on the GET functions. You will likely need the NELEM(E,NPOS) to get the I, J, K node numbers for each element. Then use the NORMNX(N1,N2,N3), NORMNY, and NORMNZ to get the X/Y/Z direction cosines. See Section 8.3 in the Modeling and Meshing Guide for info on reorienting element faces (likely ENSYM). —
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
