January 25, 2023 at 7:17 am
FAQParticipantWhen the particle collision-breakup model is used, streams with insignificant mass or numbers in parcel are deleted. It is possible to decrease the minimum mass or number of particles in parcel. Use the text user interface commands, (rpsetvar ‘dpm/minimum-parcel-mass 1e-25) and (rpsetvar ‘dpm/minimum-parcel-number 2) I have checked these for Fluent 6.1.22 in Linux platform. Copy and paste these commands as they are in the main Fluent console. You might change the values that I have specified.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
