Tagged: 18.2, fluent, fluid-dynamics, General, MP - Eulerian MP Flow, phase-change, solidification
January 25, 2023 at 7:17 am
FAQParticipantThe liquid fraction is calculated internally based on whether the temperature is above or below the solidification/melting temperature.
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
