September 26, 2022 at 10:15 amSolutionParticipant
Download the file here
Application example of a simple loading being applied to a replacement hip. The high-stress locations and overall part deformation can be visualized and measured using both Explore and Analyze mode. This project requires the release 2020 R2 or newer. The below images are displacement contours for Discovery explore and analyze mode.
- Ansys Discovery: Topology Optimization
- Discovery: Porous media coefficient calculator
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- In-Depth – Fluids Simulation using Ansys Discovery
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Structural Simulation using Bolt Idealization
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Discovery Analyze Mode – Unable to view or change material properties.
- Ansys Discovery: Activating Beta Feature
- Discovery Refine mode – Viewing mesh
