September 26, 2022 at 10:15 am
Solution
ParticipantDownload the file here
Application example of the flow distribution in a duct with 1 inlet and 2 outlets is simulated, with a goal of ensuring uniform distribution. The impact of changing the duct shape and/or including features such as internal vanes to ensure uniform flow distribution can be studied. Below are the velocity contours (Composite result display) of the flow. This project requires release 2020 R2 or newer.Explore Mode
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Ansys Discovery: Topology Optimization
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery – Defining new material
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Ansys Discovery: Activating Beta Feature
