September 26, 2022 at 10:15 amSolutionParticipant
Download the file here
Application example of the flow distribution in a duct with 1 inlet and 2 outlets is simulated, with a goal of ensuring uniform distribution. The impact of changing the duct shape and/or including features such as internal vanes to ensure uniform flow distribution can be studied. Below are the velocity contours (Composite result display) of the flow. This project requires release 2020 R2 or newer.Explore Mode
- Ansys Discovery: Topology Optimization
- Discovery: Porous media coefficient calculator
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Discovery Analyze Mode – Unable to view or change material properties.
- In-Depth – Fluids Simulation using Ansys Discovery
- Ansys Discovery: Activating Beta Feature
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Structural Simulation using Bolt Idealization
- Discovery Refine mode – Viewing mesh
