September 26, 2022 at 10:00 am
SolutionParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Problem Specification
Consider the geometry in the figure below. The slender bar is 3 inches wide, 2 inches tall, and 50 inches long. The large block on the end of the bar is 9 inches wide, 6 inches tall, and 6 inches long. Both are made of structural steel with a Young’s modulus of 2.90075E+7 and a poisson’s ratio of .3. The left end of the bar is fixed to a wall, and the geometry is subjected to standard earth gravity. Calculate the maximum equivalent stress in the geometry.
Geometry
The following video will walk you through creating your geometry inside ANSYS AIM.
Mesh
The following video will walk you through how to mesh your geometry .
Physics Setup
The following video will walk you through applying all of the required forces and boundary conditions to your model.
Results Evaluation
The following video will walk you through computing and analyzing your results.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
