September 26, 2022 at 9:59 am
SolutionParticipantProblem: While using Discovery AIM, the following error occurs:
hwloc has encountered what looks like an error from the operating system.
Socket (cpuset 0xff00ffff) intersects with Socket (cpuset 0x00ffffff) without inclusion!
Error occurred in topology.c line 940
Please report this error message to the hwloc user’s mailing list, along with any relevant topology information from your platform.
Cause: This error occurs if hyperthreading is turned on.
Recommended Solution: If hyperthreading is on, please turn it off (typically done in BIOS) and try again.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
