September 26, 2022 at 9:59 am
SolutionParticipantDownload the file here
Application example of the solid temperature in a board with a heat source and a heat sink is simulated. The impact of changing the shape and size of the heat sink, within the constraints of the enclosure, on the max temperature on the surface of the board can be studied. This project requires release 19.2 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
- FAQ: Missing Areas of the User Interface in Discovery Live
