September 26, 2022 at 9:53 am
SolutionParticipantDownload the file here
Problem: When opening Discovery products 2019 R2 via subscription license, you may receive the following license error:ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
Cause: This is possibly because of an issue in retrieving the host ids from the system on ansysls_client.exe startup. To confirm this:
- Type %temp% in Windows Search and locate .ansys folder.
- Locate the file named ansysls_client.****.log
- Open the file and check for error “Received a fatal signal C0000005: ACCESS VIOLATION”
Recommended Solution: Reboot the machine and if the problem persists, follow the steps listed below:
- Go to folder C:Program FilesANSYS IncShared FilesLicensingwinx64
- Rename the file ansysls_client.exe to ansysls_client.exe.old
- Download the attached ansysls_client.exe file and paste it in the same folder.
- Add a new environment variable ANSYSLS_CLIENT_USE_ALT_HOSITD_METHOD=1 to the list of system variables on your machine.
- Reboot the machine
Note: This solution is applicable for 2019R2 version only and once 2019R3 is available, a complete uninstall and reinstall to 2019R3 is recommended.
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- Discovery Subscription license – Command line options
- ANSYS Discovery: Compatibility Utility
