June 6, 2022 at 9:58 am
FAQ
ParticipantWe do not recommend using JScript macros. They are undocumented, unsupported and relatively difficult to use. We recommend using ACT. ACT is documented, supported and relatively simple to use.
You can change the name of reaction probes using the following commands:
newProbe = ExtAPI.DataModel.Project.Model.Analyses[0].Solution.AddForceReaction()
newProbe.Name = “MyProbe”
- How to resolve “Error: Invalid Geometry”?
